POLL: Your LCD/DLP Front Proj. optimum viewing distance?
Discussion in 'Displays' started by Andrew Lillie, Aug 18, 2003.
  1. Andrew Lillie
    Andrew Lillie Auditioning
    Dec 3, 1998
    9
    Hi everyone,
    I would like to get a feel for optimum viewing distances with various LCD/DLP front projectors. Optimum would mean a smooth picture without pixelization/screen door/visible video lines.
    I'd like to suggest the following poll. Please share the following with the forum, (if you would, copy and paste the following and add your info). Obviously this will be very subjective, but the more of us that respond, the better idea we will all get.
    -start copy-
    Projector:
    Native Resolution of Projector:
    Primary Source (eg, DVD, HD, NTSC, PAL?):
    16:9 Image Size (diagonal):
    Optimum distance from screen to viewer:
    Minimum distance from screen to viewer that you find comfortable:
    Comments (eg what do you use to upconvert etc):
    -end copy-
    Background info:
    There seems to be a lot of information out there about screen size, viewing angles, screen width and height. Ther are also some wonderful calculators to figure out where to put the porjector. I am struggling however to get a good grasp on the best possible eye-screen distance for various projectors and resolutions. For example: I know that NTSC is best at about 5-7 screen heights. I have also heard that 1.5 diagonal picture widths is good for HDTV. Well, where does DVD fall on a 16x9 front projector with enhancements like de-interlacing and conversion to higher resolutions? Do you change your sitting position depending on what source you are watching? Would you like to?
    much appreciated
    Andrew
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Projector: Sony VPL-VW11HT
    Native Resolution of Projector: 1366x768
    Primary Source (eg, DVD, HD, NTSC, PAL?): DVD
    16:9 Image Size (diagonal): 96"
    Optimum distance from screen to viewer: 12ft
    Minimum distance from screen to viewer that you find comfortable: 8ft as field of view gets overpowered
    Comments (eg what do you use to upconvert etc): Just using the progressive out from a JVC DVD player. HDef looks amazing in either 1080i or 720p.
  3. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    5
    Ron
    Projector: Panasonic PT-L200u LCD
    Native Resolution of Projector: 16:9
    Primary Source: 100% DVD
    16:9 Image Size (diagonal): 80"
    Optimum distance from screen to viewer: 12'
    Minimum distance from screen to viewer that you find comfortable: 9'
    Comments (eg what do you use to upconvert etc): JVC Progressive Scan player.
    Peace Out~[​IMG]
  4. mark alan
    mark alan Supporting Actor
    Nov 19, 2002
    620
    Projector: Sanyo PLV-Z1
    Native Resolution of Projector: 16:9 (960x540)
    Primary Source: 60% DVD, 30% NTSC, 10% HD
    16:9 Image Size (diagonal): 84"
    Minimum distance from screen to viewer that you find comfortable: 7'
    Comments - Use an older (2000) Sony DVD player, interlaced. I have never seen any interlacing artifacts, so as far as I am concerned, the Z1 does a great job of converting. The pixel structure is always visible at less than 6 feet, sometimes visible between 6-10 feet. I have no problem watching up close.
  5. Andrew Lillie
    Dec 3, 1998
    9
    Any of you X1, PT300U owners want to jump in?
    thanks
    A
  6. JohanD
    JohanD Stunt Coordinator
    May 22, 2003
    180
    Yes do jump in! [​IMG]
  7. Mark Amayao
    Mark Amayao Stunt Coordinator
    Dec 13, 2001
    156
    Projector: Sanyo PLVZ1
    Native Resolution of Projector: 964X544 16:9
    16:9 Image Size (diagonal): 92" DIY GRAY
    Optimum distance from screen to viewer: 10-12 FEET
    Minimum distance from screen to viewer that you find comfortable: 8 FEET
    I use a JVC XVFA90BK Progressive scan DVD-A/V Player.
    Very very very slight defocus when viewing under 10 feet.
    over ten feet, defocus not necessary. I think its 1.5 X screen width.
    [​IMG]
  8. EarlR
    EarlR Stunt Coordinator
    May 13, 2001
    71
    Projector: JVC G-15
    Native Resolution of Projector: 4:3
    Primary Source (eg, DVD, HD, NTSC, PAL?): DVD, HD
    16:9 Image Size (diagonal):135 inches
    Optimum distance from screen to viewer:20 feet
    Minimum distance from screen to viewer that you find comfortable:17 feet
    Comments (eg what do you use to upconvert etc): Rock Pro scalar and Panamorph lens.
    Earl
  9. Andrew Lillie
    Dec 3, 1998
    9
    Thanks all, please keep the stats coming. We are collecting some good info. When we have enough, I'll tabulate the data and post so we can see them all side by side. There is the same thread over at avsforum and I will combine the results.
    HTF: 5 posts (with actual numbers).
    AVS: 3 posts
    [​IMG]
    X1, L300U owners, please let us know how you are setting yours up.
    awesome!
    Andrew
  10. JonathonSan
    JonathonSan Stunt Coordinator
    Feb 13, 2003
    80
    16:9 Image Size (diagonal): 82"
    Optimum distance from screen to viewer: 13 FEET
    Minimum distance from screen to viewer that you find comfortable: 13 FEET
    While the image is fantastic for the price, I am very susceptable to screendoor. Any bigger or closer and I can't watch comfortably. As it is with a slight defocus, I still can catch screendoor occasion and it is a bit distracting.
  11. Nick Sievers
    Nick Sievers Producer
    Jul 1, 2000
    3,481
    Projector: Sony VPL-HS10
    Primary Source: 90% DVD, 10% Gaming. Don't have HD where I live.
    16:9 Image Size (diagonal): 105"
    Optimum distance from screen to viewer: 14ft
    Minimum distance from screen to viewer that you find comfortable: 14ft, I wouldn't want to be much closer at this size.
  12. Mark-C
    Mark-C Stunt Coordinator
    Oct 6, 2000
    140
    Projector: Panasonic PT-AE300 LCD (PT 300U)
    Primary Source: 90% DVD, 10% PAL TV
    Comments (eg what do you use to upconvert etc): Denon 2800 MK2 Progressive scan player and Progressive Scan TV Tuner
    I did used to notice screen door when I first installed this after my PT-AE100 but now I hardly notice it at all even at 9'
