Polk speaker question
Discussion in 'Archived Threads 2001-2004' started by Brian Bowles, Dec 19, 2001.
  1. Brian Bowles
    Brian Bowles Second Unit
    Dec 3, 2001
    256
    I had Polk RT-5 speakers. I just added 2 RT-25i speakers and a CS-245 as the center. I would think that the rt-5's should be the front speakers since they are a little larger. My concern is that the rt-25i speakers might sound better than the rt-5 speakers. Would it be wrong to put the rt-25i speakers in the front? Do you think they are better sounding speakers? Would this affect the volume of my home theater system? Thanks for your time!!!
  2. Danny Tse
    Danny Tse Producer
    Nov 1, 2000
    3,185
    I believe the RT5 was the forerunner of the current RT35i. Since the RT25i and the CS-245 are voice-matched, you should try them up in front first and use the RT5 as surrounds.
  3. Thomas_A
    Thomas_A Second Unit
    Feb 2, 2001
    398
    If you have a sub..by all means put the rt25i's up front with the cs245i... that way your fronts will be timber matched..wich is much more important than the size of the speakers IMO..
