JohnMW
- Dec 1, 2000
- John
Has anyone had a chance to demo these speakers? I plan on getting a nice SVS 20-39PC as well.
Thanks.
Thanks.
1) I am concerned that the 55i's for the fronts might not output as well compared to the 800i's. What do you all think?
2) Would the Polk RT55i's or the FX500i's work best for the rear surrounds? The 55i's are 100.00 cheaper as well.
3) Also, would you all recommend hanging the rear surrounds on the wall or using speaker stands?
1: 800s will go a little lower but don't sound as refined IMO. If you will run them small, I would recommend the 55s. The 55s will go plenty loud.
2: IMO, the 55s if you are willing to move the couch away from the back wall a few feet (I'm assuming this is your setup). If not, get the 500s and mount them on the wall.
3: See 2.
In any case, I can recommend the 400 center channel speaker.
http://www.hometheaterforum.com/bbs/equipment/28687.html
