WayneW
- May 15, 2002
Hi All,
Over the past couple of months, I've started building an HT setup, starting with sources and ending with the speakers. After many days of research, auditions and purchases, I am finally on the last leg of my fun albeit expensive journey. I have narrowed down my speaker choices to either the Polk LSi line or the Axiom line -- specifically Polk's LSi 15 Towers with matching LSi center vs. the Axiom M50s and VP150 center. Given my equipment list and room dimensions, can any one give me some insight/advice?
Preamp/Processor : Rotel RSP-1066
Amplifiers : Acurus 125x5 5 Channel Amp (Center, Surrounds), *Parasound Halo A23 125x2 (Mains)
Sources : Toshiba SD4700 DVD Player
Monitor : 53" Panasonic RPTV HD 16:9 Monitor
Subwoofer : Sunfire True Sub Jr.
I will most likely go with matching surrounds once I've decided on the two mains and centers, as those are my primary concern right now. The Parasound is still up in the air, I may still go with an Arcam FMJ25, which puts out less power but is probably a better sounding unit...I am also concerned which amp (Arcam or Parasound) will match better with the Acurus/Rotel combo. I may also opt for a second Sunfire Junior, if the low frequencies don't fill in well.
This is primarily an HT setup, but it will see some use as a music system as well, especially with dvd-a and music dvd's, or even the occassional cd. My room area isn't very large, as I live in a rowhouse in the city. It's an area measuring approx. 17' x 13' with an open walk way and kitchen/barstool counter on one of the longer sides of the room.
I can audition the Polks at my local dealer (Soundscape of Baltimore) and I even have a contact within the Polk organization itself (HQ'd in Baltimore). My interest in Axioms, on the otherhand, result from reading through many a review and thread across the net and finding only good things said about them. The price difference isn't huge, as I can get the Polks for about ~1400 for the LSi 15's and center (from acousticsounddesign), which is only ~400 more than the Axioms, so I am mainly concerned about the quality of the sound -- clarity/detail of highs and mids, and tightness (quality) of bass. Any advice would be hugely appreciated Thanks!
