Polk Audio speakers for $399.99!
xAbre1200
Justin
xAbre1200
Justin
So do you think this is a good buy? Can these Polk speakers compare with HSU Ventriloquist or the Energy Act6?
Alon Goldberg
Alon Goldberg
I've yet to find a HTiB speaker set that I was satisfied with, much less any speakers under $500, so I'm the wrong person to ask. Was just posting the correct URL.
xAbre1200
Justin
Will someone else help me then? Some people tell me that the Polk system is garbage...... other people say its a good buy..... which is true? My room is about 25 x 30 and im using a 10yr old Sony AVR
Alon Goldberg
Alon Goldberg
For a 25 x 30 room (750 square foot) you will be hugely disappointed by satellite speakers. I would highly recommend you audition tower loudspeakers for your fronts, and a far more capable subwoofer.
What is your primary use for these speakers? Movies or music?
xAbre1200
Justin
I will be usally watching movies. I was mistaken, my room is more about 15 x 20. I will probably be be getting these Polk ones or the Energy Act6 or Hsu Ventriloquist.
timZa
Tim
Since your just looking for opinions i think Polks suck. sorry i have no experience with the other brands you named. like the other poster said, you may very well be disapointed with that size room.
Alon Goldberg
Alon Goldberg
I also avoid Polk, especially at this price range. Personally I would lean towards the Hsu speaker package, but that being said, I haven't heard any of the three packages.
What receiver do currently own?
xAbre1200
Justin
Looks like I wont be getting these Polk speakers after all *sigh*. I am now looking into a few speakers.
1. JBL SCS300.7
price - $699.00
2. Hsu Ventriloquist VT-12/STF-1
price - $498 factory-direct; $744 list in stores
3. Energy act6
price - 800.00
(these three i found on this website, http://www.soundandvisionmag.com/art...2&print_page=y)
4. BIC Acoustech Cinema Series 6 Speaker System
price - 799.00
(and the 4th speaker is found here,
http://www.sounddistributors.com/buynow.asp?prid=1054)
I am currently using a 10+ yr old sony receiver (i know, its time for an upgrade) and it has no speaker out jack.
frogpond
Chris Baker
You have a pretty wide budget from 300 to 900. For one if you get a set you will most liekly need to get a new receiver. Either the HSu or the SVS package as they both come with excellent subs;
https://svsound.com/store/index.cfm?...TOKEN=72402536
The above link is for the b-stock (may have blemishes) which is where I got mine although mine had no flaws what-so-ever.
gullfo
