Polk Audio PSW250?
Discussion in 'Speakers' started by ChrisLazarko, Aug 14, 2003.
  1. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    Just curious on this unit and how good it's frequency responce is? How low can this sub usually reach. It is a fairly cheaper sub running only about $200 or so.
    Thank you for any input, I am just inquiring about it.
  2. EricSm
    EricSm Stunt Coordinator
    Aug 29, 2002
    109
    It'll probably be strong to about 35hz and then trail off steeply after that.
  3. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    Its -3dB point is 40Hz and the power supply is only 50 watts continuous. In other words, it'll pretty much go silent around 35Hz and it probably isn't hitting 100dB at any frequency unless you've got some major frequency reinforcement by the room itself.
    My advice: Polk subs are their weakest product. Save up for something better.
  4. Jeff-Watson
    Jeff-Watson Stunt Coordinator
    Sep 10, 2002
    184
    Jeremy is correct. I believe IMHO that Polk offers some of the best cost to performance speakers around but their subs just fall a little short. For the money look at the Sony WM40 via the net or the new wm500 at your local Best Buy. If you can wait and save for awhile SVS is a no brainer for a killer sub at a great price. Good luck on your hunt.
  5. Kevin Golding
    Kevin Golding Stunt Coordinator
    Sep 6, 2001
    61
    I bought one for my first subwoofer, and realized its shortcomings pretty quickly. Jeremy's right -- on an Avia sweep, it was pretty much silent by 35Hz. I built a Tempest based Sonosub to replace it and heard what I'd been missing. I would recommend just about anything else.
  6. ChrisLazarko
    Aug 13, 2003
    867
    Well the good thing is it is dual-rear ports and that leads to a big enclosure behind the TV. About enough to fit maybe two humans in and when I put it in that corner it just blasts away and it sounds much better, although it can be garbled in turned up too high and in that corner.
    Thank yo ufor opinions, I guess I will go and look at some new subs.
    How about the Klipsch KSW-10, or does that fall kind of short as well?
