Plz help me choose my speakers!!!!!!!!!!
Discussion in 'Speakers & Subwoofers' started by kuttaS, Jul 26, 2003.
  1. kuttaS
    kuttaS Stunt Coordinator
    Jul 21, 2003
    111
    okay i am looking between JBL NSP II paired up with PB10 thats costs about $360 total. now i found one another cool speaker system on ebay. it was Harman Kardon 5.1 speaker with 4 HKB4 sats, a center and subwoofer. it was for $409. plz suggest me which one is better. the url is http://cgi.ebay.com/ws/eBayISAPI.dll...&category=1499
  2. BobAlbano
    BobAlbano Second Unit
    Dec 10, 2001
    293
    kuttaS,
    While both of the speakers that you are looking at will be good performers I would suggest checking out what some of the internet direct speaker companies have to offer. www.av123.com has a Rocket Tyke system coming out that is a really cool titanium looking speaker. This system is a complete 5.1 system and will be sold for $499.00. I would also check out what Ascend has to offer as well as both of these companies seem to offer great bang for the buck. Good luck with your decision![​IMG]
  3. Steve Adams
    Steve Adams Second Unit
    Oct 20, 2001
    432
    the Jbl I think would be the best thing. imo, check out the sound and vision with the 35 speaker systems for under 2000! great systems.
  4. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    I second the JBP NSP1 option,
    I think JBL is a great company for entry level setups, The NSP1 is very good. You sould make search in the forums and read all the reviews.
    The only thing that I would change is the sub, try to go with the PB12 or if you want to stay in the price range go for the SA-WM500.
  5. kuttaS
    Jul 21, 2003
    111
    has anyone even used the HK HKB4 bookshelf speakers and the HKC center because they retail for like $200 a pair and ebay has them for $409 for 5.1 setup.
  6. kuttaS
    Jul 21, 2003
    111
    which speakers do you guys think will perform better with the H/K AVR 225 receiver.
  7. james e m
    james e m Second Unit
    Jun 3, 2001
    497
    Don't get the HK speakers. Rule of thumb buy speakers from speaker (only) companies.
    James
  8. Steve Adams
    Oct 20, 2001
    432
    I second that opinion james, except in a few "freak" incidences. i.e. sony sa-wm40 sub. that is a great budget sub....im going to get the new 700 i think. even tho I have a no sony policy! Im not a fan of any hk gear...
