Plugs For Speakers
Discussion in 'Archived Threads 2001-2004' started by AbelM, Jan 7, 2002.
  1. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    What's the difference between the 2 kinds of plugs for speakers? I have seen regular normal Monster cable, and then I have seen these kinds that look like RCA jacks?? What the? How do these plug into your speakers?
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    RCA jacks? Only if you have amplified speakers that I've seen, unless you are talking binding posts that accept bannana jacks or unscrew to accept spades or bare wire.
  3. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    What does Amplified mean?
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Speakers that have their own amps built into them, so all you need to supply them with is signal.
  5. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Oh, that could be it then...huh? Oh well...thanx man!! [​IMG]
  6. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Hey Brett DiMichele, yeah it looked exactly like that...does that mean you need a special type of receiver and speaker??
  7. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Do you have a pic of banana plugs? Becuse I am pretty sure I have those, but how do they go into the speakers (the wires I mean)
  8. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Brett posted a pic of the wires terminated with plugs.
    http://www.crutchfield.com/S-CQAZuEs...p?i=0732531034
    These are binding posts.
    Some speakers and some amps have them. There's a hole in the middle of them that you stick the banana plug into.
    If there's a plastic plug in the middle of your binding post, you have to use bare wire or a spade connector.
    - CM
  9. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Ok, yeah I have these for my mains and center, but not for my rear. Huh, but how do they connect to a speaker that has regular connections?
  10. ColinM
    Dec 9, 2001
    2,050
    Regular as in spring clips? (Tabs)
    You MUST use bare wire. No options.
  11. Michael Cook
    Michael Cook Stunt Coordinator
    Dec 25, 2001
    238
    You can use the bannana plugs on one end for your receiver and then bare wires at the other end for your speakers. Not to sure if it is even worth doing, but you can buy the bannana plugs at radio shack.
  12. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Thanx guys!!
  13. JasonKZ
    JasonKZ Stunt Coordinator
    Dec 12, 2000
    191
    Anyone else have an opinion on if it is worth spending the money on banana plugs?
  14. ColinM
    Dec 9, 2001
    2,050
    Really truly, it's a convienience thing for me. I like bare wire, but my receiver is a pain to feed wire into. So I use banana's on the rec. side of things.
    If it weren't for the pain in the butt, I'd stick with bare wire.
    But that's me. I can still appreciate a nice set of plugs/jacks. Nice to look at, but does nothing for the sound.
  15. James Bergeron
    James Bergeron Supporting Actor
    Oct 9, 2001
    831
    Bare wire is best, I find my speakers EASY to get bare wire into, but my receiver a pain. It's bi-wired so I put 1 set of wire bare and the other set with plugs to make it easier, still a pain but easier! hehe
  16. Dan Cabral
    Dan Cabral Stunt Coordinator
    Jun 26, 2002
    69
    How do you guys feel about speaker pins over bare wire?
  17. ColinM
    Dec 9, 2001
    2,050
    I have no idea what pins are used for. Maybe for the anti-spade collars on some posts?
  18. Nick V
    Nick V Second Unit
    May 7, 2002
    421
    Some spring clips have holes in them that pins fit nicely into. My fried has a kenwood receiver and his 12 guage wire doesn't fit into the spring clips. So, I told him to purchase some pins, and he said that they fit perfectly.
    HERE is a picture of the spring clips.
