Plugging "holes" in speaker cabinet
Discussion in 'Archived Threads 2001-2004' started by Chad Anson, Feb 20, 2001.
  1. Chad Anson
    Chad Anson Second Unit
    Feb 13, 2000
    377
    I drilled four holes in the bottom of two of my speaker cabinets for speaker spikes. The hole does not penetrate the cabinet but does go in 3/4". I decided to only use three spikes per speaker and need to plug two of the holes. Any suggestions? Silicone caulk? Wood putty?
  2. Chad Anson
    Feb 13, 2000
    377
    After doing some research, it seems that "Bondo" available at any auto supply store may do the trick. . .
  3. DanWiggins
    DanWiggins Second Unit
    Aug 15, 1999
    324
    Chad,
    Another great material is "Fix-All". It's like a very fast drying, much harder plaster. Comes in a powder, you mix in water, and use quick! Sets in about 8-10 minutes, and hardens in around 30 minutes. Hardens to a firmness of cement, doesn't shrink, and doesn't wet your wood at all.
    Great stuff for plugging small holes and gouges, leveling panels, or patching broken walkways!
    Dan Wiggins
    Adire Audio
  4. Chad Anson
    Feb 13, 2000
    377
    Thanks Dan! Is 'Fix-All' available at Home Depot/Walmart/etc. ?
  5. DanWiggins
    Aug 15, 1999
    324
    Should be! Fun stuff to work with. I've used it in many a different app, from filling holes in cabinets, to leveling countertop surfaces for laminating, to patching the cement in my garage... [​IMG] Nice universal stuff!
    Dan Wiggins
    Adire Audio
