Plenum and which RG6?
Discussion in 'Archived Threads 2001-2004' started by Rob Lloyd, Sep 18, 2001.
  1. Rob Lloyd
    Rob Lloyd Stunt Coordinator
    Mar 22, 2001
    234
    I'm in the planning process of building a new house. So far I've got the plenum Cat5e cable and now am trying to decide which RG-6 to get. Do I need plenum cable for the inspector?
    I was thinking of using Canare L-5CFB for everything. Is there something better or just as good but not as much $$?
    Rob Lloyd
  2. andyg
    andyg Agent
    Jun 30, 1997
    49
    You should be able to find out what are the codes in your town. In my case I had to ensure any wire I was installing was CL-3 rated (in-wall use). It may vary in your area. You should be able to find any CAT5 or RG-6 with this rating. I would suggest a CL-3 RG-6 Quad-shielded with a solid copper core.
    ---Andy Garabedian
