Please review my DIY ultra low budget dual sub setup
Discussion in 'Home Theater Projects' started by Wes T, Jan 14, 2004.
  1. Wes T
    Wes T Stunt Coordinator
    Apr 11, 2000
    55
    After two short years of ownership the one nice piece of equipment that I have, my Yamaha YST SW800 sub, fried while I was watching T3. Although I am sad that the one nice expensive thing I have in my otherwise cheap HT died, I now have an excuse to buy new stuff. Of course, I am really low on funds. Afer much research here and other forums I have decided on the following. I picked up an MCM 250 watt plate amp for 89 dollars. I had the biggest problem finding suitable drivers until I stumbled on the MCM 12 inch high excursion woofer MCM 55-2330. I just got two of these today and I am astounded at how great these look and feel for the low price of 58 dollars each. These seem to be the bang for the buck kings that I have found with the biggest Xmax for dollar I could find. After crunching the numbers for this sub in WinISD I need to build a box at 3.8 cubic feet with a 9 inch deep 4 inch port to yeild a FS of 26 Hz. The response curve is flat all the way down to 30 Hz. I plan on building 2 of these boxes and running them in parrallel off of the MCM amp. My reason for two of them is because I grew up on the old school stuff from the 70s when you had 2 big honkin' speakers, and I don't like the way my system or many others I have heard sound with just a single sub. I want it to sound like the stereos of old where you had bass on both your left and right sides, even though I am going to be running them summed from the one amp. So what do you all think? Am I going to bathing in gobs of clean bass or is my system going to sound like a cheap-ass disaster?
    2 questions. Do I pack any polyfill in the box and is there a poor man's way of adjusting the phase besides by ear?
    I would appreciate it very much if anyone can point out any glaring errors in my plans or offer me any tips on doing this better without costing any more money.
    Wes T
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Line the interior walls of ported boxes with damping material. Don't 'stuff' (pack) the box.
    The only poor mans phase adjustment is by reversing the driver leads so it's 180 degrees out of phase.
  3. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    OK ThomasW, help me out here. Many ported sub designs call for polyfil i.e. the Adire Alignment with 64 ounces of polyfil. You're saying this is incorrect?
  4. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    He's saying not to completely fill (pack) a ported enclosure whereas this is fine in a sealed sub. Lining the sub walls with layers is fine as long as the fill isn't too close to the port openings.
  5. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    That's correct. And probably the best way to do this is to go to a fabric store that sells sheets of polyfill by the yard. Pick up a few yards of polyfill and then staple it to the inside of the cabinet walls. This should keep the polyfill away from the ports and amplifier.
  6. TimForman
    Dec 4, 2002
    847
    Oh, I don't know about that. I like the "indoor snow" effect. [​IMG]
    I thought that might be what was meant by that statement, just wanted to make sure. BTW, I've heard good things about the MCM drivers you've chosen. Good luck![​IMG]
  7. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    I agree with the sheet poly fill and lining the walls of the cabinets to start for sure..
    Later, (if you feel like playing a little), you can always experiment with adding a little extra fill to taste. An SPL meter and Hz-test disc is of a great way of seeing just what effect this has on the tuning, in room extension, and over all freq response...
    Hey the snowing effect is fun, well once anyway!
    I'm not familar with the MCM drivers you have choosen, but assume their 8-ohm load per driver. Thus when wired up P, the amp will see a safe 4-ohm load.
    Best of luck with the project, and your more than likely DIY hooked from here on out!
    Tuff break on the Yammi-800, but you'll be Bass'en again soon...
    Cheers
    Geoff
  8. Wes T
    Apr 11, 2000
    55
    Wow. Thank you all so much for all of your responses! Since it looks like things are going to work OK I am heading out to home depot to get some MDF. Hopefully, they will cut all the pieces for me and all I will have to do is assemble the cabinets. I will get some roll batting and line the inside of the enclosures with that, taking care not to get it too close to the port. I will staple it tight in a 6 square inch area behind the port.
    Geoff, yes the MCMs are 8 ohms. Thanks for assuring me on the load for the amp. Back when I started I used an Apexjr amp with two old radio shack mach twos for bass. They worked pretty good. The amp is still used today for bass shakers at a 4 ohm load and it works fine.
    ThomasW. The reason I was asking about phase adjustment is because the MCM amp has a variable 0 to 180 degree phase knob on it. I will work with that later as I learn more about properly tuning my system for my room. The more I read about tuning the more complicated things get. Gone are the days when you just plopped down a pair of big butt speakers and called it done eh?
    Thanks again all. -Wes
  9. Wes T
    Apr 11, 2000
    55
    Got the first one built today. Wow! Nice and very low bass. It is funny, I first hooked it up to my ApexJr amp that normally drives shakers and I had it sitting a few feet out from the wall. You didn't hear much bass until you walked all the way out of the room. I replaced the amp with my MCM 250 and put the sub in it's new place and I am astounded at the sound this thing makes for under a hundred dollars! I can't wait to add the second one! I have one mis-cut board from the L place that I have to get replaced before I can finish the second enclosure. I don't need to finish the enlosures with anything since my whole system is hidden so the raw MDF finish looks great. I am now a total believer in DIY bang for the buck! Pics coming. -Wes
  10. Wes T
    Apr 11, 2000
    55
    The subs are done and I couldn't be happier! They sound spectacular. I get very smooth and low bass that sounds great with my music and movies. They easily get up to 110db at my listening position and I am very pleased with the even sound I get from two of them. At a total cost of around 300 dollars for everything I am extremely happy. Pics are here http://photos.yahoo.com/westanizer
    -Wes
  11. TimForman
    Dec 4, 2002
    847
    So, do you still miss your Yamaha sub? [​IMG]
  12. Shawn Shultzaberger
    Shawn Shultzaberger Supporting Actor
    Dec 2, 2000
    705
    Nice goin' with the subs! [​IMG]
    Now for a few questions:
    What are you going to finish them in?
    Did the lumber place cut the wood for you?
    Did they cut the holes for the subs also?
  13. Wes T
    Apr 11, 2000
    55
    I don't miss the yamaha as much as I miss the 500 dollars I spent on it! All of my cheap JVC stuff still works. Why can't any of that break?
    To answer your questions Shawn, for now I don't plan on finishing these. My entire system is finished in fabric covered panels that conceal all of my speakers and gives me that built-in look. All you see is the fronts of the equipment and the TV. If I do ever finish them there is a thread going on using spray on truck bed liner that gives a very interesting and durable finish. These puppies are pretty big so I am glad they are out of sight. A guy at Lowe's cut the MDF for me. If you find someone who is good with a saw they can do fairly precise cuts. MDF is real forgiving and easy to sand out also if the cuts aren't perfect. I cut the circles using a dremel tool with a circle attachment. I got a set of the bits with that attachment for Xmas and it made cutting those circles a breeze! -Wes
  14. Michael.Hoffman
    Aug 2, 2002
    33
    10
    I like the way you have your components built-in like that. I assume your panels are removable for future expansion? By the way nice job on the subs.[​IMG]
  15. Wes T
    Apr 11, 2000
    55
    Thanks Micheal! The panels are all stuck on with velcro and pull right off. There is even enough room behind my equipment rack for me to stand behind it to work on it. The panels are 1/4 inch masonite with 1x2 frames and fabric stretched around them and are pretty much built like speaker grills with cutouts for the speakers. I just thought it up one day when I was looking at my crummy looking entertainment center. It has worked well, is easy to clean, has been very durable, and it keeps the kids and cat from messing with things. It was also a bit of a compromise I had to make to get the TV on the same wall as the fireplace. I still say a big screen would fit nicely in the spot where the fireplace is.[​IMG] -Wes
  16. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Ahh.. another member of the "nekkid" speaker club. [​IMG]
    Going back to your original post:
    MCM is great for inexpensive drivers.. and some of them can be pretty nice. I've been happy with my 8" livingroom sub using their 55-2195... that is, until they doubled the price on that driver. [​IMG]
