Please recommend protection for my PC
Discussion in 'Computers' started by Holadem, Aug 11, 2003.
  1. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
    Affordable protection that is [​IMG]
    I have had broadband for a couple of months now, my computer is constantly on. The trial version of MCcafee expired a couple of days ago, and I guess I am all nekkid now... I will probably buy the damn thing. Before I go ahead, i do have a couple of questions:
    1 - I have a Norton Antivirus 2000 or something lying around, I believe I used to get free updates a couple of years ago, would it still offer adequate protection?
    2 - I know nothing about firewall, and I am not about to buy another PC (even a cheap one) just for that, are there affordable software protections?
    Basically, what do I need to get to be reasonnably safe online?
    Thanks much.
    Holadem
  2. Steve_Tk
    Steve_Tk Cinematographer
    Apr 30, 2002
    2,833
    I have Norton's Firewall, it's not expensive, it's just software. Just to let you know, I get attacked probably 3-4 times a day with a SubSeven Backdoor Trojan Horse that it blocks. Now I don't know what that means, or what it can do, but I'm glad I have the firewall up.
  3. Patrick_S
    Patrick_S Producer
    Apr 1, 2000
    3,278
    102
    4,110
    I'd get a hardware-based firewall with NAT to protect yourself from intruders and of course get your anti-virus software up to date.
    The truth is that no network is 100% safe but like anything else the ones who want to do harm generally start with the low hanging fruit first and then work their way up.
  4. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
    If you go to the "deals" section (gotapex.com), I think it was either today or yesterday, there is a 802.11b and 10/100 router for $19.99 with 1cent shipping. It was not specified, but all 802.11b and 10/100 routers these days have buildin hardware firewall, and I assume it's true in this case, so you can get that for $20, download a free copy of Zone Alarm (or some such), and if you look hard, you can get Norton System Works (which inludes NAV) 2003 for almost free, or just go to EBay, you should get one including shipping for about $12. So for about $32, you get a wireless and 10/100 router, hopefully with buildin firewall, software freebie firewall, and Norton, I think that's pretty good.
  5. Francois Caron
    Francois Caron Cinematographer
    Jul 31, 1997
    2,143
    Francois Caron
    Holadem, if you have Windows XP, go to the Control Panel and double-click the "Network Connections" icon. Right-click the entry that corresponds to your high speed Internet connection and select "Properties". Go to the "Advanced" page and click on the "Protect my computer..." checkbox. You now have an active firewall. For added protection, you should also perform the same operation on the entry related to your network card.
    Perform a final test of your security with the SheldsUP! test available at http://www.grc.com . If there are still any open holes left in your configuration, this site will tell you where they are.
    For the antivirus protection, you can install Grisoft's free antivirus program which you'll find at http://www.grisoft.com . You can even set it to perform automatic updates and virus scans at specific times.
    Total cost: $0.
  6. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Router. Router. Router.
    Accept no substitute.
  7. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    Rob beat me to it. Forget software firewalls. Get a Linksys, D-Link, or Netgear broadband firewall.
    Computer security 101
    Rule #1: Never install a firewall on the system that's being protected.
    Rule #2: If you take the bad advice from people who suggest that you violate rule #1, prepare to re-read rule #1 in the future after someone breaks into your system.
    Zone Alarm is fine is you want to use it to protect yourself from programs that are reporting out to the Internet without your knowledge. Just remember rule #1 if you're considering using it for inbound protection.
    If privacy is important, change your Mozilla/IE settings to reject cookies from any site other than the site that you're visiting, and get your hands on AdAware (www.lavasoftusa.com) to get rid of spyware/malware/adware.
  8. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    Aside from a router, the cheapest way to protect yourself is to NOT DOWNLOAD CRAP AND DOUBLE CLICK ON THEM. [​IMG]
    You receive an email. You see an attachment. DON'T OPEN IT.
    Be sure to enable "show file extensions" and "show hidden files" and UNcheck "hide file extensions on known file types". Hopefully that will convince Microsoft Outpuke (Express) to cough up the file extension of the attachment YOU SHOULD NOT OPEN ANYWAYS. [​IMG]
    DON'T SAY YES when your browser wants to open an ActiveSuX control, unless you really KNOW what you are doing. I read the dialog box very carefully. Clicking yes may expose you to viruses and trojans that may actually download CHILD PORN onto your computer (Acquitted man says virus put porn on PC ). I usually let Microsoft ActiveX controls run, but I still double check the webpage and make sure it really is from Microsoft.
    Cloudmark (http://www.cloudmark.com/) is a very effective spam and virus blocker as well...works with Microsoft Outpuke and hopefully soon will support Outpuke Express. I have not gotten a single piece of spam because of this outstanding program.
    DON'T RUN KAZAA. Don't run any file-sharing program at all if you can resist the temptation. They are a known source of viruses and trojans, and are spyware to boot. File sharing sucks -- although I suppose BitTorrent may not suck as bad or so I hear. But, whenever you run a filesharing program you ARE exposing yourself...
  9. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
  10. John_Berger
    Nov 1, 2001
    2,489
  11. MikeAlletto
    MikeAlletto Cinematographer
    Mar 11, 2000
    2,369
  12. John_Berger
    Nov 1, 2001
    2,489
    Agreed. Kazaa Lite and LimeWire run just fine.
    Between a hardware router, Ad Aware, and a good virus scanner, with perhaps Zone Alarm to watch for unauthorized outbound traffic, you should be golden. This of course assumes that you keep Ad Aware and your virus scanner up to date on a regular basis. [​IMG]
  13. Rob Gillespie
    Aug 17, 1998
    3,632
    5
