KevinQ
- Aug 6, 2001
Hi, Guys,
I have the Kenwood HTB504 package. I am planning to upgrade my front L & R speakers within a budget of $300. I might spend up to $500 to $600 (including stands) if improvement is substantial. I would like the speakers to be as neutral as possible within that price range. (I mostly use Sennheiser HD-600 and Sony 7506 headphones for music now)
The room is about 10 by 16. The use would be 90% music and 10% movie. My music preference is 80% classical (orchestra, chamber, opera), 10% Jazz/vocal, etc. The original Kenwood front L & R will be used as the surround L & R. I will keep the Kenwood 8" sub for now, and will upgrade in the order of center/L&R/sub in next 6 to 12 months if I get into multi-channel SACD/DVD Audio.
The speakers must be shielded. After search the forum, I found there are several popular bookshelf recommendations:
JBL studio: s36/38 won't fit my setup. I might buy S26 II + studio center ($330 from etronics.com)
Axiom: M3Ti ($275, matching stands cost $90)
Paradigam: Mini Monitors (not sure how much)
I highly appreciate you recommendation on which brand/model to audit.
Kevin
Kevin
