please post thoughts on denon's 3802
Discussion in 'Archived Threads 2001-2004' started by peter a, Jun 26, 2002.
  1. peter a
    peter a Stunt Coordinator
    Jun 18, 2002
    96
    quality receiver for the price? what advantages vs. disadvantages are there to this receiver vs. something like the onkyo 898 or the yamaha rxv-3200. totally new to this HT thing... would like some advice. thanks. also, can i run the denon 3802 at 6 ohms? thanks in advance..
  2. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    I just upgraded to the 3802. So far I love it. I like the sound of the Denon over Yamaha and Onkyo for music. The 3802 should be the cheapest of the 3. You should go listen to each to see which sounds best to you. You should also listen to Marantz and HK. What speakers are you connecting the receiver to? This makes a big difference in sound.
  3. peter a
    Jun 18, 2002
    96
    bobby-
    thanks for the advice.
    i hope to go with axiom speakers.
    m80s (rated at 4 ohms- will that be a problem)
    surrounds (not sure which axioms yet)
    VP150 (center channel)
    svs sub:
    either 20-39
    or 16-41 pci
    let me know... thanks.
    peter
  4. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    The Denon's specs are here. The 3802 is spec'd for 6 & 8ohm loads. There are numerous people on this board who are driving 4ohm speakers with the Denon w/o any problems.
