Jarrod Ferris
- Jan 23, 2003
I just purchased a JVC 48" 16x9 set and I think it's totally defective. Has anybody heard of a problem where anytime a bright object moves on to a darker scene it throws a circular, almost lens flair blob of light up on the opposite side of the TV. Depending on where the light source is, it will make a circular light flare up on the screen, just opposite it.
I know it's not a lens flare that was in the film. I know this because 1) the light blob goes over top of black bars on 2.35:1 movies, and 2) the lens flair effect will appear even from the brightness of calling up my TV menu screen.
I also know that my settings are good. I used a calibration DVD to set it.
I was able to ignore this for a few days, but now it is getting worse, with even hints of blue and red in the flares.
Does any of this sound familair! Is it defective? HELP!!!
