please help!
Discussion in 'Speakers' started by Ian Stange, Apr 16, 2004.
  1. Ian Stange
    Ian Stange Auditioning
    Apr 15, 2004
    ok i have a 12 inch sub from my car.. and i want to hook it up in my basement to the home theatre in the basement.. how would i go about doing that?!?!
  2. Johnal
    Johnal Stunt Coordinator
    Mar 14, 2004
    131
    Johnal
    Unfortunately, I can't offer advice on how to do that, but I have read other posts similar to this request and usually the outlook is not so good. For future reference though, you will get a lot more "hits" to your post if you are more clear in your subject line as to what your post pertains too. [​IMG] I wish you the best of luck though!
    -Johnal
  3. Johnny_M
    Johnny_M Second Unit
    Apr 6, 2004
    281
    is it a powered sub? if it is youll have to get an ac/dc converter. a non powered sub is easy, just plug into your sub out if your receiver has it, if not, youll need an external amp.
    Johnny
