Please help with KOTOR.
Discussion in 'Gaming' started by Brion Lydon, Sep 18, 2003.
  1. Brion Lydon
    Brion Lydon Stunt Coordinator
    Sep 20, 1999
    140
    I'm on Manaan and am trying to overload the fuel injectors to get rid of the shark. Does anyone know the sequence I use to get the fuel injectors at 4 million? Thank you!
    Brion
  2. James T
    James T Screenwriter
    Aug 8, 1999
    1,643
    If I remember the riddle correctly, fill up the one that holds 3, dump it in the one that holds 5. Fill up the 3 again, then dump that in the 5. Empty the fuel injector 5 that is now full. Empty the 3 fuel injector into the 5(should only be 1 in there). Fill the 3, and empty it in the 5 to get to the 4.
    Hope I didn't make it complicated. It's actually an old riddle...it was also used in Die Hard 3.
  3. Rob Varto
    Rob Varto Supporting Actor
    Mar 5, 2000
    711
    Yep, James has it right. I spent about 15 minutes on that one just last night. Im sleepy as hell today, but it beats poisoning the whole planet [​IMG]
  4. Brion Lydon
    Sep 20, 1999
    140
    Thank you very much.
    Brion
