Peter Gee
- Nov 20, 2004
Hi All
I just ordered a new Toshiba 62HMX84 HDTV with HDMI input and I want to add a DVD player also with HDMI.
Q. Since I'm using HDMI for video, should I not be concerned that the player I'm considering (Toshiba SD5970 with HDMI Video Upconversion) only has a 10 bit 54MHz Video D/A Converter?
OR should I go for a higher priced Denon with dual 12bit 216MHz video converters?
There seems to be differing opinion on whether or not the quality of the D/A video converter will matter since the HDMI is an all digital connection.
Many Thanks,
Peter
Many Thanks,
Peter
