Please Help With Discrete Codes to Program MX-500
Discussion in 'Archived Threads 2001-2004' started by Daniel Mai, Nov 24, 2001.
  1. Daniel Mai
    Daniel Mai Stunt Coordinator
    Oct 2, 2001
    225
    I'm looking for power on and off discrete codes to program into the MX500 for:
    1. Mits SR-HD400
    2. Panasonic DVD RP-91
    3. Mits VCR HS-U746
    Thanks.
  2. Andrew V
    Andrew V Stunt Coordinator
    May 11, 2000
    197
    If you know someone with the Philips Pronto remote then they could get those codes from Remote Central and teach them into the MX-500.
  3. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    Daniel: Go to the Home Theater Master section of http://www.remotecentral.com They can help with lots of tweaks and questions relating to your MX-500.
    In addition to the Pronto idea Andrew brought up, you could check and see if the One-For-All Cinema 7 can create the discete codes you want/need. A great resource for the all things Cinema 7 is http://www.hifi-remote.com/ofa/
  4. Daniel Mai
    Oct 2, 2001
    225
    Thanks, Chuck and Andrew. I was hoping to get help here since I know a lot of people here owns either a Pronto or HTM-MX500.
