Please Help, What's the best way to break in Paradigm Speakers???
Discussion in 'Archived Threads 2001-2004' started by Dan Da Silva, Nov 1, 2001.
  1. Dan Da Silva
    Dan Da Silva Stunt Coordinator
    Feb 14, 2001
    71
    The subject lines pretty much examples my question, thanks for the help
  2. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    Play them like you normally would. Preferably continuously if you can for several days straight.
  3. Denward
    Denward Supporting Actor
    Feb 26, 2001
    552
    It's best to use the tuner so you don't wear out any moving parts on the rest of your system. Depending on your neighbors, you should play it loud while you're out of the house.
  4. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    Dan,
    It depends on the model. If they are reference speakers, then do the following:
    1. Pack speakers back into cartons.
    2. Drive speakers to my place.
    3. Go back home.
    4. Wait for me to call you when speakers have been broken in (probably at least a couple of months).
    5. (Optional) Return to pick up speakers.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    It's been that kind of day so far. I needed that.
    Seriously, just play, play, play.
    Doug
    "Today is a good day to die." ...Old Lodge Skins
  5. Mike_T_
    Mike_T_ Stunt Coordinator
    Oct 30, 2001
    198
    I have the Studio 100's and have just listened to them. Carefully at first, not pushing them too loud or too much bass. I've heard of people putting on some pink noise while at work. It really is fun to hear the speakers come into their own over time. Paradigm says not to critically listen to them until at least a few hours of break in. I've heard that 50 hours is what they really need before they reach their peak performance..
  6. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    Play them on non-critcal source to start with. Like TV or tuner use. Give them around 50 hours before giving them the critical listening test.
  7. Dan Da Silva
    Feb 14, 2001
    71
    sorry I forgot to tell you guys that I have a pair of Mini-Monitors V2, and a CC-370 as my center. The mini's are singing right now but the CC-370 just has this harshness in the tweeter right now. like almost static on voices. I'm thinking that there is something wrong with the tweeter.??
  8. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    The speakers should play fine right out of the box. If you hear unnatural noises from your speaker, take it back for an exchange. If it's playing w/o distortion, make sure that your levels are properly set and that you don't have any sort of EQ on that channel.
    Greg
