Please Help - Need Small Audio/Video Receiver (hopefully with Built in DVD Player) (1 Viewer)
danash80
dan ash
This is for my master bedroom. I want to get some speakers hooked up as the sound coming from my TV isnt stellar. I have a cable box, appletv, and a dvd player (all use HDMI). I am looking for a small a/v receiver so i can hook up all the components and have speakers to provide better sound. It would be even better if the unit had a built in dvd player, but that isnt necessary. I found harmon kardon has one (http://www.harmankardon.com/EN-US/Products/Pages/ProductDetails.aspx?PID=BDS%20370/120) but I don't want to spend $900 on it.
Anyone have any suggestions?
Martino
Santa Clara, CA
Martin O.
When I finally get around to upgrading the system in my bedroom from a 4:3 CRT system to a 16:9 high def unit, I am going to go with a zvox system to place under it to improve the sound...the sound of the new flat panel TVs is just terrible...
These systems start at $200.00....and you hook up the output from your TV to the input of the zvox....and then turn the TV's speakers off. The zvox also learns your existing remotes volume control...so you just use whatever remote you are currently using to change your volume....
Your TV acts as the hub - so whatever you see on the screen will be heard through the zvox. However you are currently switching sources with your TV will continue to work.
http://www.zvoxaudio.com/
Yllanes
