Please Help! Mp3 & Music Match
Discussion in 'Computers' started by Eric Stuckey, May 14, 2003.
  1. Eric Stuckey
    Eric Stuckey Second Unit
    Mar 24, 1999
    421
    Hi
    I am using V 7.5 Music Match Plus .Im trying to burn all of the Star Wars soundtracks to a 80min CD-r Using MP3 formate.My problem ( And its about to drive me insane ) Is No mater what box's I UN check in the burner Options tab, IT STILL PUTS THEM in ABCDEFG order.I went to the MM homepage and it said to UN check sort files when burning.I DID THAT and it still burns in ABC order.I did read that it says that windows will auto put data files in ABC order,but i made sure it is in MP3 formate.
    I add the tracks to the playlist.Then hit CD-R . The burner plus box pop's up and it does show the tracks in the order I placed them in the play list.But never the less,When I play the disk back on my truck or partable MP3 player ...AHHHHHHH its in ABC order.WHAT AM I DOING WRONG????
    Eric
  2. Mike_Thor
    Mike_Thor Extra
    May 7, 2003
    20
    You might consider renaming the MP3 files so that the track number is in the beginning of the file name. ie: 01 - Death March
    That way if it is alphabetically, it doesn't matter.
