Please help me with the tv
Discussion in 'Displays' started by Agustin, Jul 3, 2003.
  1. Agustin
    Agustin Agent
    Jul 3, 2003
    41
    Hi guys, in this right moment i have a little money to spend and i want to buy one of these three models, so you can help me to chose?
    2 mods are samsung and one Mitsubishi, the strange fact is when i saw the 42"Samsung and the Mitsubishi the samsung image looks better, and i cant reflectme on the screen, and in the mitsubishi i reflect everything. so please help me
    http://www.samsung.com.mx/samsung/po...ction/pkey/578
    Samsung 32" Widescreen Flat Tube
    http://www.samsung.com.mx/samsung/po...ction/pkey/624
    Samsung 42" Widescreen RP
    http://www.epinions.com/Mitsubishi_W...ay_~full_specs
    Mitsubishi 42" Widescreen RP
    WT-42311
    all of them support HD
    thanks for your help
    well little is something to say
    i have 1600 dollars
    the 32" Wide HD cost 1320 dollars
    the samsung RP cost $1600 dollars
    and the mitsubishi $1650 dollars with the base
    007 Acdbulls
    [​IMG]
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Yes, some models have "anti-reflection" screens. Some people like them, others feel they blur the image.
    You have to decide for yourself if you want this or not.
    Samsung has not had a good reputation until the last year or so. Mitsubishi is one of the better brands, but the Mitsubishi televisions will NOT accept 720p from say a video game or decoder box.
    I'd go with the Mitsubishi unless the 720p issue is a problem for you.
  3. Agustin
    Agustin Agent
    Jul 3, 2003
    41
    Thanks, i think Mitsubishi would be a cool option, by the way do you know how much are the cost for the lamps in both cases and how many hours of life have?
  4. Bob McElfresh
    May 22, 1999
    5,182
    I believe these are CRT based televisions. They have tubes/guns and not lamps like a DLP unit. The cost of replacing these is almost as much as buying a new television.
    I was told the expected life of a typical RPTV is around 5000 hours.
    The DLP televisions are different. They have a single high-intensity bulb that can be replaced for about $250 after 4000-6000 hours. None of the models you listed are DLP's.
  5. Hugo
    Hugo Stunt Coordinator
    Nov 21, 2002
    147
    Agustin, you got email!!!
