Shana
- Jun 16, 2002
I'm moving my "entertainment" room into the living room from the den. I am going to have to have DirecTv put in there as I only have it in the den for now. I am purchasing a DVD player and speakers to go with my TV and receiver.
I'm having a lot of work done on my house including new flooring and there is an opening in the ceiling currently right above where the entertainment center will be (I'm assuming it goes up to the attic) due to mold issues. So I am needing advice on how to set up the speakers and all the wires, inc. the new directv receiver. I'm wondering if there are some things I need to tell the contractor to do while my house is in such a mess that would benefit my set-up.
I have no idea how to set up 6 speakers. Could the wires be put under the laminated flooring, could something go to the attick via a small hole where there is no ceiling right now?
Any advice would be very helpful. I feel that this would be the time to make any changes that would help later.
Thanks so much!!
Shana
Thanks so much!!
Shana
