Please Help Me With My Dlp Picture!!!
Discussion in 'Displays' started by Jon Accamando, Nov 17, 2003.
  1. Jon Accamando
    Jon Accamando Auditioning
    May 28, 2001
    12
    I recently purchased a Samsung HDTV Directv Receiver. The 160 series. I already have the HLN507 Samsung DLP. I am connecting the two using the DVI cable. Now, my picture is horrible. The HD channels are similar to a normal digital feed from the cable I had. The other channels are very blurred and grainy. I am running a 75ft cable from the satellite to the receiver and the signal strenth is in the 90's from the satellite.
    What possibly could be the cause of this? I have spent too much money on my set-up to get poor quality like this.
    ANYONE !!! PLEASE !!! HELP !!!
    -Jon
  2. Jon Accamando
    May 28, 2001
    12
    Ya...I tried all connections and checked all menus. All good. I just went out and bought a signal amplifier to try that. I hope this works.
  3. Rajeev_s
    Rajeev_s Stunt Coordinator
    Dec 20, 2002
    184
    75ft Cable could be the problem, I dont think you can use long runs for DVI cable. Its the limitation of using Digital cable. You might want to look into using shorter cables by moving things around or invest in a multiple amps for DVI.
  4. John Doh
    John Doh Stunt Coordinator
    Jun 24, 2003
    199
    I think the 75ft he is talking about is from the dish to the receiver (coax), not the DVI cable from the receiver to the TV.
    Which sattelite service do you have? I know through Direct TV, you need a multisatelitte dish to pick-up HD signals. The standard DTV dishes won't get it for you. Just a thought.
