Jeff Lund
- Oct 30, 2002
I think I've lost all my data, 3 years worth of work and leisure. Outlook .pst, several crucial applications, 30GB of mp3's, tons of Star Wars multimedia files, among other vital documents. I'm soooooooo depressed right now. 80GB down the drain.
Here's the short version. I recently added an SIIG ATA 133 PCI controller card along with a 120GB Maxtor internal HDD to serve as my back-up drive. Last night I decided to wipe out my system (it was getting extremely sluggish) like I've done hundreds of times before, although never with an extra drive in the mix. Anyway, I attempted to install Win98 (for gaming only) and then Win2K for a dual boot. Something went very wrong with the '98 install. So I decided to start over and install DOS (my old reliable ancient process) and then '98. When that didn't turn out as I planned, I just installed Win2K Pro from the bootable CD. All went fine.
Until I went to Disk Management to re-add the 120GB HDD. Win2K basically said that it needs to format the drive and says there is no data on the HDD. I don't know what went wrong and how to fix this.
Did the '98 or DOS attempted installs inadvertently format the HDD on the ATA controller bus? I didn't see anything like that happen but who knows. So what do I do? Can I retrieve my data? Should I try taking the 120GB HDD off the ATA controller bus and add it as a 2nd HDD (I already have 2 HDD's installed....I'll just swap the secondary HDD out)? If necessary, I'll send my drive out to be rstored if the data is gone. If it comes to that, who do I contact and what will they charge me? Has anyone had any experience with this scenario? Hopefully, it won't come to that.
I sincerely hope you guys can help me out with this task as you have in the past. Any and all suggestions, information, and wisdom is greatly appreciated. Please respond here of contact me directly via e-mail: [email protected]
