Please help me hook this stuff up! (1 Viewer)
carlw
OK, so I just got digital cable and since I had to reconnect things anyway, I figured I would finally set up the receiver to do all the switching for me.
But... after connecting the vcr, I have sound but no picture. What is the proper way to hook the vcr up?
Right now I am running composite from cable box to receiver (TV input). Then composite from vcr out to vcr in on receiver, and vcr out on receiver to vcr in.
I also have the dvd player running composite video to receiver, then only the composite video out on receiver to the tv.
What am I doing wrong?
Lee Carbray
Carl, how do you have the receiver hooked up to the TV. You only need one cable to go from your receiver to your TV. Make sure you have the Tv on the correct input as well.
carlw
Yes I have only a single composite video cable going from the receiver to the tv. I know I am on the right tv input cause I am able to watch cable & dvds...
Any other posibilites?
Bob McElfresh
Just for grins,
- Set the receiver to "VCR" so you get sound
- Take the composite cable from the CATV box and plug it into the "VCR IN". Since you know the CATV video is comeing through the cable, this will test the VCR IN on the receiver.
I'd also remove the cables going FROM the receiver TO the VCR until you get this problem fixed. You could have a cable plugged into the wrong jack.
carlw
OK, I am a dum dum. :b
I had the VCR in/out on the receiver backwards, works great now!
Thanks guys!
superbolix
