DaveNaumann
Grip
- Apr 7, 2002
I have started to construct my tempest sonosub. However, I have a few questions about the design I must answer before I can finish it. I am using a 20" sonotube and will be powering it with a pe 250 watt plate amp. After reading through adire's recommended box designs I feel that the vented adire alignment suits my listening tastes the best. I basically would like to mimic that enclosure using a sonotube. I figured on keeping the 214L volume and 15.4 Hz tuning point. I was wanting to use a single 6" port instead of the 2 3" flared ports. However, when I use lspcad it shows that if I use a single 6" port it must be ~35" long. Is 35" too long for a 6" dia. port? Or should I just raise the tuning point to shorten the port? Also, when stuffing the sub, is it better to use batting around the tube or to just throw loose polyfill in the enclosure? If anyone has any other tempest enclosure recipes feel free to share. Thanks in advance for the help!
Dave
Dave
