jeff lam
I'm going to get cable from comcast and I need a wireless router to connect one desktop hard wired and a notebook wireless. There are so many to choose from and I'm not familiar whith which ones are best. I need it to be good quality, secure, reliable, and have good performance. I was planning to just go with B but I think G may be best (mostly for the expanded range right now). I need suggestions on a good router that will be able to connect a printer as well so I can print from either computer.
What does everyone suggest for a good router/wireless notebook adapter combo?
Remember I need reliability(connection), security, and performance.
I will spend a little extra money if it's worth doing.
Any help would be appreciated... Thanks!
