Please help finding a replacement bulb (1 Viewer)
My company has a MCSi MC-X2500 LCD projector that I need to find a replacement bulb for. The problem is, that company went out of business.. does anyone know where I can order the bulbs? The unit also says "Radiant" on it..
Any help would be great!
Rob
Ramon A
If you go to yahoo search and type in projector bulbs you will find a bunch of places that sell replacement bulbs.
if you can't find one there you may need to buy a new projector. good luck
mrossum
