Al.Anderson
- Jul 2, 2002
- Al
Normal speaker wire is fine. You don't have to break it apart; for instance, if you're going to use the banana plug for you connection to the receiver and the hole for the bi-amp, and both wires fit in the hole, then great ((the more stands the better). If not, don't worry about it either; and if you think it'll confuse you or someone else later, then break it apart.
If it were me, I'd probably use a spade connector to jump the posts, and the banana connector to run to the receiver (so the spade can stay permenantly tightened and the banana plug can be removed if you have to move the speaker.
