Please help? Apartment toilet wont flush!
Discussion in 'Archived Threads 2001-2004' started by McPaul, Mar 15, 2003.
  1. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,795
    50
    Vancouver
    Paul M
    whenever I press the handle it tries, the water churns for a second or two but no flushing. Thankfully it doesn't fill with water either with each attempted flush!
    I don't want to get the super involved as I've had a stomach virus the past few days and the toilet's a little "used" [​IMG]
    I have to go somewhere for a couple hours tonight, hopefully that will give it time to "settle" but if there are any plumbers out there who could provide a possible solution I would greatly appreciate it!!
    Thanks for any input!
  2. Drue Elrick
    Drue Elrick Stunt Coordinator
    Oct 30, 1998
    101
    Try holding the handle down until its done emptying the tank. Sounds like the chain on the handle inside is too long or lose and the water exit cover is being sucked closed before all the water exits.
  3. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,343
    Adam
    In the meantime, if it's a conventional toilet, dump a bucket of water down it (or a saucepan of water). This will flush it.
    Adam
  4. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    It's probably clogged, a plunger should do the trick.
  5. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,795
    50
    Vancouver
    Paul M
    well, I pulled the cover off that thing this morning (ewwwwwwwww) and tried pulling the chain myself, no go. (although it did flush once late last night when I got home). The water level in the bowl never rises (which is a good thing) I tried dumping a couple liters of water down the tank and it didn't seem to help either (pulled the chain and the only thing that happened that time is the bowl filled up a bit more with water) A friend told me that if the bowl doesn't fill with water then it doesn't need plunging, but I will try it. Don't have a plunger so I guess this is a good time to get one! Will give it a try..... thx.
  6. Malcolm R
    Malcolm R Executive Producer
    Feb 8, 2002
    13,232
    889
    9,110
    Malcolm
  7. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,795
    50
    Vancouver
    Paul M
    Thanks Malcolm, that sort of did it, I filled the tank up to almost the top of the (overflow?) tube, and then tried flushing it, and it flushed! Everything went down! However, the level in the tank is VERY low. Perhaps a liter, or half a liter? Is there anything I can do to correct this? Is there something perhaps wrong with the refil mechanism?
    edit: I just put my ear very close to the top of the tank and I could barely hear a bit of hissing.
  8. david stark
    david stark Second Unit
    Jan 24, 2003
    256
    Usually in the tank there is a float attached to a metal pole. If you push the float down more water should flow into the tank and if you lift it up it should stop. Where this pole is attached to the tank there is usually a screw or something that you can turn to set where the cut of point is.
    Is water always slowly running from the tank into the bowl?? I had this problem a while ago and the rubber washer that makes the seal at the bottom of the tank needed replacing and it was always leaking so the tank never filled up.
  9. Joseph DeMartino
    Joseph DeMartino Lead Actor
    Jun 30, 1997
    8,311
    13
    Florida
    Joseph DeMartino
  10. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,795
    50
    Vancouver
    Paul M
    I don't seem to get water flowing in there constantly but that could be an issue. Now that I've got rid of my "mess" I will get the super to fix whatever the problem is, thanks for all your help everyone!
  11. BrettB
    BrettB Producer
    Feb 1, 2001
    3,019
    Since it works occasionaly, most likely the fill valve (a mechanical valve opening and closing with every use) in the tank is bad.
    If there were a problem with the water supply or shut-off valve (calcified deposits) you would either have restricted flow and it would work, albeit slowly, or it would be completely blocked and not work at all.
  12. Marc Carra
    Marc Carra Supporting Actor
    Aug 31, 1997
    767
    Why, oh why was I somehow compelled to click on this thread and read it, even though I have no plumbing knowledge??! Anyway, I'm glad you fixed the problem, Paul. One of my worst nightmares would be to have a toilet overflow its contents onto my bathroom floor. Eeeewwwww!
    Marc.
  13. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,795
    50
    Vancouver
    Paul M
    Marc... because you care about your fellow Canucks? ha, thanks, I'm the same way, I click on lots of things I don't know anything about, just to see what's up and learn something new. Nothing overflowed here, and I'm thankful, waiting for a new gasket from the super so I'm flushing manually for the time being... [​IMG]
