Please give advice on speakers... (1 Viewer)
Wayne Leon
I currently own a set of Polk Bookshelf Speakers (Monitor 10's,
I believe), a Polk cs100 Center channel, and a set of Boston
Acoustics A40 bookshelf speakers (which I have kinda used as rears). I have had them all for a while and all are in excellent shape. I, for one reason or another have never purchased a subwoofer. My problem now is....do I keep what I have and purchase a subwoofer or I have been looking at
Polks RM6200 satellite set with the PSW250, which is better?
I think I have stopped moving for a while and want to finish out my system. I don't need anything fancy...just something that sounds good. I have a Denon AVR900 receiver, which I plan on upgrading to a digital receiver. I will not buy an expensive receiver, probably one in the $500 range. So, which speaker setup above will work for me?
Looking for any and all advice,
Wayne
Jack Gilvey
This is the DIY forum, so thought you might be wanting to build a set. You might get more answers in the hardware forum.
CoolMovies
