Please demystify the 12v trigger for me...
Discussion in 'Home Theater Projects' started by Drew_W, Jan 25, 2004.
  1. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    It is my understanding that when connected (i.e. from pre/pro to amp), the pre/pro sends a signal to the amp and tells it to turn on (on cue, of course).
    Is the reverse also possible? i.e. when the pre/pro is turned off, the amp shuts off as well?
    Thanks.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Yes. It would pretty silly for the 12v trigger to be a "one way" function, wouldn't it?
  3. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    An amp I was looking at said "12 volt DC automatic turn-on circuitry".
    I just wanted to make sure it was automatic turn-OFF too. Thanks Wayne.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Yes, it works just like the amps in car stereos: The trigger acts like a remote switch and turns the amp both on and off. Buy with confidence! [​IMG]
  5. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    Think of it as a 12v outlet, when pre/pro is on then there is 12 volts on the line. When pre/pro is off, then there is 0 volts on the line. When you say 'sends a signal' I get the feeling that you are looking at this as a 'blip' when the pre/pro turns on/off. The amp has an electronic switch (or relay) in it. 0 V from pre/pro means that the switch in the amp is off, so the amp is off. 12V from the pre/pro means the switch is on and so is the amp.
