ross ish
- Nov 18, 2002
Rythmik T/S
Fs 26; Qms 7.505; Vas 88.41L; Cms .222mm/N; Mms 169.1 g;
Rms 3.681kg/s; P-dia 259.8mm; Sd 530 sq cm; Qes .59;
Re 2.698ohms; z 3.264ohms; BL 11.24Tm; Qts .547; no .1689;
1w spl 85.04Db; 2.83v 89.3Db; xmax 15mm; Pe 350 w; 1.2inch excursion;
1.6inch voice coil; 1inch surround; 102oz magnet
Stryke AV12
Fs 21; Qms 4.41; Qes .399; Qts .366; Vas 88L; Re 2.97; Z 4;
BL 15tm; Cms .25mmm; Mms 228g; Pe 500w; 1w 85.5; 2.83 89.5;
xmax 23mm; Sd 498sq cm
I was looking using either the Rythmik Direct Servo Driver/Amp combo or the Stryke AV12 in a vented 101.5liter enclosure. I do not know much about the Rythmik driver nor do I know much about the inner workings of T/S relationships.
The above Rythmik driver is designed specifically for the servo plate amp so I do not know if a direct comparison is possible; but any comments on the Rythmik driver good/bad would be appreciated. The higher F3 is due more to elevated bass than premature low roll off.
The suggested vented box has these parameters to achieve -3Db 14hz with 114Db@20hz:
110liter, Fb 20hz, F3 27.24hz, heavy fill, 1 vent round flush Dv 122.2mm, Lv 600mm
My cabinet will be 100liter vented with a single 4inch port 16 inch in lenghth flared both ends. Again any comments regarding the cabinet would sure help out.
http://www.rythmikaudio.com http://www.stryke.com
Stryke AV12
