Michael Botvinick
- Sep 13, 2001
Thank You for all the email suggestions for my Kenwood/Definitive Technology problems. MY AMP NO LOPNGER ShUTS ITSELF OFF!!!.
With your suggestions, I went to Home Depot and bought 12 gauge wire and went to Radio Shack and bought the Banana plugs you guys suggeted. I bi-wired the 2002 Def Techs (For Mid and Highs) and ran RCA cables for the low/sub. It sounds so much better and cost me under $50. I like that. When playing Toy Story two and above -42db or higher on the Kenwood it would shut itself off. No More.
Now I have abut $800 bucks to spend to upgrade my system. My kenwood is the KRV-8070 which is one of the most powerful receivers Kenwood made but it is only Pro-Logic. (If anyone wants it I will give it to them cheap or trade for something)
I think I should upgrade the AMP/Reciever. Also my rear channels and center channels are not so good (Polk Audios). I think I should buy the Def Tech center to match the sounds but what would you guys suggest?
Should I go with the Outlaw 1050?? I can get any Pioneer product at cost. So I could get a Pioneer Elite amp instead?
What rear channels speakers do you guys like. And if I get a 7 channel amp then don't I need a rear center channel to?
Please aadvise,
Michael
[email protected]
Please aadvise,
Michael
[email protected]
