Andrew W
- Jun 19, 2001
So the video store that has been selling my father-in-law his HT gear has gone out of business and his stuff is in a screwed up state. I've got audio mostly figured out, but I'd like to know the best way to set up the video.
I have:
Runco 992 Ultra CRT projector. This guy takes RGB+sync or RY/Y/BY + sync as inputs.
Sony DVP-S7000 DVD player that outputs RY/Y/BY but with no sync.
Comcast box that outputs unknown component video (Pr/Y/Pb?)
Faroudja VP400 line quadrupler. This guy takes a composite video input and outputs RGB.
A component to RGB converter by KDS.
A KDS 4x video switch.
The original config had the composite video from the DVD player into the VP400 then to the video switch. The Component->RGB was on the Comcast output and before the video switch.
The Comcast HD looked good, but the DVD picture looked like a bad PhotoShop filter due to the Faroudja. I think it's time has past. It was probably great for making VCR tapes look good on a projector, but contributing nothing at this point.
I tried running the DVD player straight into the switch, but the projector is set for RGB inputs.
My best configuration is to move the Component->RGB converter to the projector side of the switch and run the Comcast box and DVD player straight into the switch.
Is there a better setup than this? I tried setting the projector input to component video to remove the component->RGB converter from the system to avoid extra signal degradation. But this resulted in the Comcast output turning to all green. The DVD picture was fine like this even though the DVD player lacks a separate sync cable.
I'm still getting hum bars travelling from bottom to top on the DVD picture. They are mild, but I notice them. The HD output from the Comcast box doesn't seem to have them.
Any suggestions on how to make this right would be appreciated. The poor guy got a bunch of good gear, but the video store staff seemed incompetent in setting it up.
Andy
I have:
Andy
