Playstation Broadband Help
Discussion in 'Gaming' started by Adam Sanchez, Jan 23, 2004.
Tags:
  1. Adam Sanchez
    Adam Sanchez Supporting Actor
    Oct 4, 1999
    903
    Please forgive me for the dumb question I am about to ask. My brother is about to get broadband for his Computer and wants to also use it for his Playstation 2.
    Now I know all about Networking for computers, but have never put a Video Game system into the mix. I know they have those wireless gaming stations to use with the Next Gen Systems. But I was wondering can a Network cable be simply SPLIT and be sent to the computer and then the Ps2? I am guessing no, that you have to have a router in the mix, but I just thought I would ask just in case.
    He can not afford a router at this time so I just wanted to ask for him. Might there be other low cost options to do what he needs to do? Like a hub? I have an old one he can use if so.
    Thank you for the help.
  2. Adam Sanchez
    Oct 4, 1999
    903
    Bumpage.
  3. BenS
    BenS Stunt Coordinator
    Jan 9, 2001
    209
    I am also wondering the best and cheapest way to do this.
  4. Kimo Bonnelycke
    Kimo Bonnelycke Stunt Coordinator
    Feb 1, 1999
    98
    Ok, can a network cable be split into 2, YES and NO [​IMG]
    A regular cat 5 cable has 8 wires, but only 4 are used for tcpip, thus you can have 2 connections with 1 cable. That's the YES, the NO part is, you need some form of router to hook 2 computers to one high speed connection.
    What you are really asking, of course, is weather you can have two computers (or xbox, or ps2) on the same 4 wires, and that is a NO, at least not at the same time, as there would be huge issues with collisions, and MAC addressing.
    So, here is what i would do, go to www.compgeeks.com, and get a cheap router box (around 50 bucks or less). Here is a good one: http://www.compgeeks.com/details.asp?invtid=DI-704P-R
    Then you can use it to route your computer and ps2 traffic, and 2 other devices since it has a built in switch.
    You could go wireless, but the routers cost more, and you have to also purchase a wireless bridge. Going direct cat wire is the cheapest solution.
    Kimo
