playing PAL on PC
Discussion in 'DVD' started by ForresterW, Jul 31, 2003.
  1. ForresterW
    ForresterW Stunt Coordinator
    Aug 10, 2001
    102
    please let me know if I am able to play region 2 PAL movies on my computer...
    [​IMG]
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    PAL is not a problem, you will still need to hack your DVD-ROM to remove region coding and use something like DVDGenie to fix the one in Windows
  3. MartEvans
    MartEvans Stunt Coordinator
    Apr 17, 2002
    93
    4
    10
    There is a program I use called DVD Region Free (http://www.dvdidle.com/) which allows you to play other regions discs on a region locked drive.
  4. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,410
    312
    9,110
    Cees Alons
    If you don't want to mess with the firmware, buy a second DVD-drive (one locked for region 1, one, say, region 2). What do these things in the US at the moment? $30? Less than 3 DVDs!
    Cees
  5. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
    I have absolutely terrible experience with DVD Region Free, MUCH MUCH better using my 5 year old Toshiba, if one looks around, for a region free old drive (pre year 2000), $20 should do it.
  6. MartEvans
    Apr 17, 2002
    93
    4
    10
    I've been running it on Windows 2000 and XP using either PowerDVD or WinDVD without a single hitch for ages now... each to their own [​IMG]
