Playing Downloaded Movie files on DVD Player
Discussion in 'Archived Threads 2001-2004' started by KwongC, Sep 26, 2002.
  1. KwongC
    KwongC Agent
    Aug 9, 2002
    28
    I downloaded a movie from Kazaa and it is in .avi format. I burned it to a CDR and tried playing it in my DVD player. it doesn't work though. Am I suppose to convert it to another format or something first? Thanks!
  2. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    Tsk Tsk Tsk, the forum rules prohibit any discussion of pirated or bootlegged material.
  3. KwongC
    KwongC Agent
    Aug 9, 2002
    28
    I dont' think its bootlegged stuff because its video footage from someone who attended a auto racing event. Its not an actual "movie."
  4. Arnel Enero
    Arnel Enero Stunt Coordinator
    May 2, 2002
    106
    Doesn't the forum prohibit hasty accusations as well? [​IMG]
  5. Martin Fontaine
    Martin Fontaine Supporting Actor
    Aug 15, 2001
    626
    Ok, if it's not some Theater Handy-Cam or DivX rip of a DVD, then it's legal to help you.
    You have to convert the AVI to an MPG file in VCD format (Which is a specific audio and video bitrate) And then using your CD Burner program, burn that MPG file as a VCD (Not as a Data disk)
    A site that gets recommended here for VCD creation is http://www.vcdhelp.com I've never been there but I think you'll find what you need there.
  6. KwongC
    KwongC Agent
    Aug 9, 2002
    28
    what's a "theater handy-cam?"
    thanks, I'll check out that site...
  7. Andrew Chong
    Andrew Chong Supporting Actor
    May 7, 2002
    739
    "theater handy-cam" is essentially a handy-cam used by law-breakers who film a movie as it plays in a theatre and sells and distributes copies of the recorded movie to equally law-breaking takers.
  8. KwongC
    KwongC Agent
    Aug 9, 2002
    28
    who the heck would want to buy it, let alone watch it? the quality must be abyssmal..
  9. Jo_M
    Jo_M Stunt Coordinator
    Dec 12, 2000
    168
    Oh people do watch them and buy them. Most people who buy them will get it on the street and not realize how bad it is. I think the majority of CAM releases are downloaded off the internet.
  10. Dave Getson
    Dave Getson Stunt Coordinator
    Nov 15, 2001
    167
    Kwong,
    Does your DVD player play burned CD's? Music or otherwise? If not, that's definitely your problem. If so, it might not play burned VCDs or SVCDS. Many different factors could contribute to it not being able to play. You could try converting the .avi file to a .mpeg. That might do something.
  11. Justin Ward
    Justin Ward Supporting Actor
    Jun 6, 2002
    673
    At vcdhelp.com they have a list of DVD players and their compatibilities to VCD, SVCD, MP3 etc... You should check out that list first.
