Playing 2-channel w/ digital coax cable?
Discussion in 'AV Receivers' started by Jesse Sharrow, Jan 19, 2004.
  1. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    I have a toshiba older dvd player, a yamaha rxv-440 receiver, and a pair of boston acoustics speakers. I set my reciever to know that I only have 2 speakers. Now when I first hooked it up I just hooked up the digital coax cable and poped in a movie and it didnt do anything. Then I hooked up an analog connection also and it works fine. Does that mean a digital coax cable wont send stereo to the receiver?
    Reason I ask is I dont want 2 different cables hanging out back there, and I have a better digital coax cable than analog cables and I dont want to go buy anymore cables right now.
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    I'm not sure why you didn't get sound through the digital connection. Probably a configuration issue with your receiver.
    With two speakers, you will want to take advantage of your player's ability to downmix 5.1 tracks for 2-channel output. That ability works on the analog outputs; I'm not sure if it's available on the digital output (and if it is, you'd need to change the player's output option to PCM).
    M.
  3. Paul_A
    Paul_A Extra
    Dec 1, 2003
    20
    Make sure that you have the digital out option selected in the setup menu of your dvd player when using the coax cable.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Make sure the DVD player is set to PCM too, especially if you hear nothing at all...
  5. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    You shouldn't need to set it to PCM, but that should guarantee you stereo via digital. The thing you need to check is that you have the digital input assigned to the source you are using, which it doesn't sound like you have done. You typically cannot connect both analog and digital fron a single source to the same input, and/or you may have the digital input you are using assigned to a different source.
    The player will not do this automatically, but since the receiver knows there are only two speakers, it should take care of it in much the same way. Also, if you select the stereo track on the disc, if available (normally there is), there will be no issue.
