Any quick ideas for riser / step / platform for second level of home theater seating? Obviously I could call in a carpenter to custom make them. Just wondering if there was any other options?
The other option is to build it yourself. I built a rear riser about 9" high and it's pretty easy if you have basic carpentry skills. I used 2X8's every 16" and a piece of 3/4" OSB for the top. I glued the top down and also used screws. Then I glued down indoor/outdoor carpet from Home Depot.
