Cam McFarland
- Feb 6, 2004
OK...got my amp from CSS Mondau & it came with no instructions. I emailed them for some help that night & have gotten no reply as of yet.
The amp is not enclosed, so I think I am supposed to build a box to cove the back so as to not leave the circuit board, etc. exposed inside enclosure, right?
What do I do with the wires which have the driver connections from the amp.
Do I just notch the edge of amp enclosure to fit over wires, then calk it?
Also, the seperate control panel with amp gain & crossover
(I guess) that has to get back to amp, has an open back as well with exposed circuits.
The same question applies here.
Thanks.....Cam
Thanks.....Cam
