JohnA
- Oct 25, 1999
My sealed Maelstrom box is coming along nicely with few problems. The few issues I had where easily overcome with help from this board and a little patience on my part.
I am considering how to mount the plate amp and driver. The plate amp will be mounted in a "pocket" located on the rear of the enclosure. It will seal the amp from the subwoofer enclosure.
I am unsure if I should just pre drill and screw right into the MDF enclosure or go to the trouble of using T-Nuts.
My concern with using T-Nuts is that I may split or chip the MDF installing them.
I would like to hear what other people have done.
-JohnA
-JohnA
