PLASMADOCS.COM ZENITH P60W38 60" PLASMA DISPLAY MONITOR BLOWOUT!
Faroudja/Sage DCDi Processor / 1366x768 / 1000 cd/m2 brightness / 1000:1 contrast
** THIS IS A LIMITED TIME OFFER TO STOCK ON HAND **
** ONCE THEY ARE GONE THERE WILL BE NO MORE AVAILABLE **
*** THIS ITEM HAS FREE SHIPPING ***
Price : $6999 SHIPPED! List $16,999
INFORMATIONAL LINKS
Product Spec Sheet
DOCTORS THOUGHTS
This is one amazing display for the money. While many 60" screens cost more than $10,000 and this one does retail for $16,999, but we have a limited supply of these amazing displays for way less than half of that. For a very limited time this display with 1366x768 resolution, 1000 nits brightness, 1000:1 contrast ratio WITH a Faroudja Processor built in is going for $6999 SHIPPED!!! That's right, making it cheaper than the bargain basement plasma shops for a one time blowout! Ask our competition if they are an authorized dealer and if your display needs repair who are you going to call? For under $7,000 you can get a display that is extremely bright, with an excellent contrast ratio WITH a faroudja/sage DCDi processor which is state of the art. It just doesn't get better than this for the price. Check out our competition and ask them if they have any...or if they can touch this price.... We think not! That is the PlasmaDocs difference. The difference from a 50" set or a 42" set is staggering. You feel like you step into the picture its so clear. The key is the amazing scaling processor by faroudja. It's simply amazing.
MANUFACTURER COMMENTS
The P60W38 60" Plasma HDTV employs groundbreaking display technology delivering superior image clarity, color and brightness. The P60W38 features extremely detailed imagery, extremely sharp contrast between light and dark images, and renders an incredibly bright picture, even in well-lit areas. The P60W38 allows intelligent resizing of video and computer images to 16: 9 widescreen or 4: 3 conventional formats. Faroudja/Sage scan converter seamlessly converts TV video data to PC formats without distortion or cropping images in either 4: 3 or 16: 9. The P60W38 is compatible with DVD players, VCRs, computers, digital broadcasting, multimedia and traditional video sources. The Digital Visual Interface (DVI) provides an uncompressed transfer of high definition video from a digital video source to a digital display device. HDCP (High Bandwidth Digital Content Protection) ensures copy protection of the content.
MANUFACTURER DATA
60" Plasma HDTV Monitor
Groundbreaking display technology delivers superior image clarity, color and brightness in large-format televisions that are less than 4" thick
1366 x 768p Resolution
High resolution format produces extremely detailed imagery
1000:1 Contrast Ratio
Extremely sharp contrast between light and dark images
1000 cd/m2 High Brightness
Renders an incredibly bright picture, even in well-lit areas
Aspect Ratio Correction
Intelligent resizing of video and computer images to 16:9 widescreen or 4:3 conventional formats
Intelligent Image Scaling
Faroudja/Sage scan converter seamlessly converts TV video data to PC formats without distortion or cropping images in either 4:3 or 16:9
RS-232 Controls and NTSC, HD, VGA, SVGA, XGA, SXGA and DVI Inputs Compatible with DVD players, VCRs, computers, digital broadcasting, multimedia and traditional video sources
DVI with HDCP
Jacks Include: DVI with HDCP, Hi-Res Component Video, S-Video In, Composite In, RGB In (15-Pin Type-D Connector), Audio In, Audio Out, RS-232c
P60W38/38H - Zenith 60" 16:9 HDTV Monitor Plasma Display
Jack Pack
DVI with HDCP 1
Hi-Res Component Video 1
S-Video In 1
Composite In 1
RGB In (15-Pin Type-D Connector) 1
Audio In 2 (L/R)
Audio Out 1 (L/R)
RS-232c 1
Cabinet Dimensions:
Width x Height x Depth 57.3" x 34.8" x 3.9" Weight 154.3 lbs.
Cabinet Dimensions with Packaging:
Width x Height x Depth 62.0" x 41.3" x 18.1" Weight 176.4 lbs. UPC Code 04464201012 6
Accessories (Optional)
Stand (D60DVMS)
Width x Height x Depth 45.7" x 15.6" x 16.3"
Weight 51.9 lbs.
UPC Code 04464200562 7
Wall Mount (PWMT-200)
Width x Height x Depth 34.2" x 17.0" x 2.0"
Weight 22.8 lbs.
UPC Code 04464240082 8
Speaker (D60DVSA)
Width x Height x Depth 34.8" x 5.3" x 3.9"
Weight 5.8 lbs. each
UPC Code 04464200542 9
Speaker Stand (D60DVSAS)
Width x Height x Depth 8.7" x 8.6" x 8.7"
Weight 4 lbs. each
UPC Code 04464200552 8
Cabinet Description
Finish Brushed Silver
Cabinet Style Slim Frame
Power Consumption 650W (Max Audio 700W)
Power Source 110v (60Hz)
Remote Control
Transmitter Yes
Service/Limited Warranty
Warranty: Parts/Labor 1 Year/1 Year
MTBF (Approx.) 30K hrs.
FEATURES
Video Enhancements
Screen Size 60"
Aspect Ratio 16:9
Resolution Display 1366 x 768p
Contrast Ratio 1000:1
Brightness 1000 cd/m2
Viewing Angle 160º
Digital Progressive Scan
Format Conversion Intelligent Image Scanning
Sage Scan Converter
Faroudja DCDi™ De-Interlacer
Color Gradation Filter
Input Signal NTSC, HD, VGA, SVGA, XGA, SXGA
Display Modes Normal, Wide, Zoom
Audio Enhancements
Optional Speakers 20W (10W x 2)
On Screen Equalizer
Gradual Volume Increase
CC When Mute
MTS/SAP
Bass/Treble/Balance
Audio Volume Leveler
Special Features
Flexible Picture-in-Picture (PIP)
Advanced Zoom
Multi-lingual Menus
Shock Absorbing Glass Damper
RS-232 Controls, Hi-Res Component, S-Video
Digital RGB (DVI with HDCP)
Auto Power On
Auto Sleep (Power/Off)
Discrete Codes
Last Source Memory
Required Approvals
UL, FCC (B)
WARRANTY INFO
1 YR Parts and Labor
RETURNS
Plasma televisions are not able to be returned save for an even exchange dut to product malfunction. To return the unit you must retain all packing materials and ship the item back to us as it came to you. The return of the display is the sole responsibility of the customer to provide shipping and insurance back to the warehouse. An RMA number is required on all defective returns. Please call to obtain one before shipping. Please note: If no notice there is any damage to the unit you must let us know immediately. DO NOT we repeat DO NOT accept the shipment if you think that the unit is damaged or has visible damage. Make notation on the shipping bill but do not sign to accept the shipment and have them return the item to their facilities for evaluation.
SHIPPING PACKAGES
Package ships in one box.
SHIPPING WEIGHT
176.4 lbs
SHIPPING CHARGES
All plasmas ship FREE OF CHARGE!
INFORMATIONAL LINKS
Product Spec Sheet
DOCTORS THOUGHTS
MANUFACTURER DATA
DVI with HDCP
Jack Pack
DVI with HDCP 1
S-Video In 1
Composite In 1
Audio In 2 (L/R)
Audio Out 1 (L/R)
RS-232c 1
Cabinet Dimensions:
Stand (D60DVMS)
Weight 51.9 lbs.
Weight 22.8 lbs.
Speaker (D60DVSA)
Weight 4 lbs. each
Cabinet Description
Remote Control
Transmitter Yes
FEATURES
Video Enhancements
Screen Size 60"
Aspect Ratio 16:9
Viewing Angle 160º
Sage Scan Converter
Audio Enhancements
On Screen Equalizer
CC When Mute
MTS/SAP
Bass/Treble/Balance
Special Features
Advanced Zoom
Multi-lingual Menus
Auto Power On
Discrete Codes
Last Source Memory
Required Approvals
UL, FCC (B)
WARRANTY INFO
RETURNS
SHIPPING PACKAGES
SHIPPING WEIGHT
176.4 lbs
SHIPPING CHARGES
