or mount a small shelf above/below the plasma (I assume the plasma will be wall mounted), and put the centre on the shelf. or get custom brackets for the centre.
You could go with a centre speaker on a stand, angled slightly upward. This would allow you more control over matching the speaker with the mains, moreso than if you went with the inwall solution. Link Removed
