Jeff Jenkins
- Dec 19, 2001
I'd like to spend under or around 7k if possible, so it will probably need to be a smaller lower-end model. The NEC 42MP3 has been the best looking one I've seen so far. This will be used as part of a home theater setup, so presentation features are not as important. As long is it supports 720p and is a 16:9 screen. Let me know what you guys recommend.. Thanks.
Edit: Sorry for the mis-post... This probably should have been posted in the Projector/TV forum :frowning:
