keenwatcher
- Nov 2, 2006
- sean
Hi out there,
I've posted before on a few different topics (favorite film genres and others), and I think I will be posting a bit more in the near future, I like to discuss movies on dvd.
My question here is:
Can anyone give me feedback about plasma image retention?
I have been watching old sixties t.v. shows on dvd (via hdmi cable and an upconverter 1080p dvd player), and the screen has two vertical bars on each side (cut down to 4:3 ratio), i have been wanting to watch it in 4:3 original aspect ratio (and not stretching it to fill the widescreen image). However, I tried two different approaches- the first was simply letting the dvd play in 4:3 format and the second was to use the aspect ratio button on my t.v. remote to goto 4:3 (and then it displays two grey bars on each side). I notice that there is a very visible vertical line on each side of the previous t.v. image (which I discovered is called image retention), the image retention is not as bad with using the grey 4:3 aspect ratio (the vertical lines are less apparent). So far, when watching another dvd filling the entire screen, the imperfections or ghost images (after images) of vertical lines go away.
In my owners manual it says:
Do not display a picture in 4:3 for an extended period as this can cause "image retention" to remain on either or both sides of the display field. To reduce the risk of such "image retention", change the brightness of the side bars.
I came across another person's post here at HTF about this "image retention" and someone replied "don't worry about it, as long as you watch a full screen refreshing show, it should go away, disappear. Its not the same thing as burn in".
My problem is, I will be watching an entire series of 4:3 tv shows on dvd and am wondering, should i stretch it (and thereby distort the original aspect ratio) and put up with the stretched image? In fear of image retention or burn in?
This also brings up a similar problem with letterboxed movies on dvd and the horizontal lines they create to display the original theatrical aspect ratio.
I notice there too, are image retention horizontal lines after turning off the dvd player. However, so far they seem to fade and disappear after viewing something that fills the entire screen for about an hour or two.
Can someone explain the difference between "image retention" and "burn in"?
I also notice that the input source selected (hdmi, or component/cable) show different backgrounds when the source (dvd player hdmi cable, or digital cable box) is turned off.
There are problems too with the logo's (usually in the lower right hand corner of the tv) of various cable news tv channels leaving "image retention" effects on the plasma tv screen, that can be seen seconds and minutes after turning off the cable box. They too seem to go away after watching something on tv without definite bright logo's that appear in the lower right hand corner.
Is this something I should worry about? or put up with? Will the "image retention" lead into a more serious problem like burn in?
There's no way to get around the logo problem, especially if one likes to watch alot of news channels... like some news-hounds out there (I have been one in the past, but less so lately)
Any input on this matter would be appreciated....
