Plasma audio help needed-I am a Newbie here! (1 Viewer)
electros
Mitch
Maybe someone can help me with what parts I need and or brands-not worried about cost- I am looking for info or what ever it takes to get this system up and running-
I am remodeling a master/bedroom and bathroom-I own an electrical construction business and can do most all of the work-I am not very good with audio but have installed several top of the line Bose home Theaters and whole house expandability before-
The problem I am having is I want a plasma/LCD TV to have simple use stand alone sound and cannot seem to get the correct info to do so- here is what I am doing and need to get all the pieces-
1) 42" plasma /LCD flat panel TV will be inset mounted above a fireplace and the box it goes in will be custom made and fitted with power and audio jacks-equipment can go into new cabinets set to the left and right of fireplace-TV will be covered with a mirror designed to let the TV picture show through when turned on-also possible an infraded repeater or hidden eye will be needed since the TV infrared may be covered by mirrors frame-
2) TV needs to have speakers outside in wall since TV is covered-what will make these speakers work?
3) Also in bedroom 5 speaker in wall home theater set up-maybe the TV sound can work through these-
4) Also bathroom will have 1 in ceiling speaker for basic music-
5) Will need to have am/fm, home theater , basic music , and basic TV sound
6) Operations as follows-
Surround sound
Basic music for bedroom and bathroom
Basic TV sound
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Mitch,
Sorry, but your post is pretty vague, which is probably why you aren't getting any responses. For instance, I can't decide if you're trying to set up a whole-house system based in the living room, or separate independant set-ups including a "fireplace" TV in a living room, stand alone system in a bedroom, with another one somewhere designated as a "home theater," or what. I also can't decide if you're asking for interconnectivity advice between these, or advice for hardware for each location, etc.
Wayne A. Pflughaupt
electros
Mitch
Wayne,
As I stated this whole system is for a master bedroom / Bathroom- fireplace is in bedroom, the theater system is for bedroom-I will have 1 speaker also in bathroom-so what I need is-
1-TV use with sound out of speakers other than the TV speakers since they will be covered up-
2) TV will have home theater surround sound-5 speakers?
3) Master bedroom 5 speakers or less plus the 1 in bathroom to play basic musci/cd
I hope this clears it up-I am just not sure what components I need-
Mitch
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Okay - guess I'm just not used to seeing fireplaces flanked by equipment racks in a bedroom...
Anyway - you won't be able to get the 5-speaker surround sound from the TV. It'll require outboard amplification, so you'll need a 5.1 home theater receiver. Get one with "B" speaker connections for the front channels; you can use those for the bathroom. You'll need a separate a source for the "basic music/CD" for the bedroom and bathroom.
Wayne A. Pflughaupt
electros
Mitch
The cabinets on either side of fireplace will be decorative and any equipment will hide inside-one side is a wet bar with a fridge the other still open but there will also be uppers-
So wayne can you give me an equipmet list? is there a TV or speaker type that can just plug in?
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Equipment list incudes:
  • 5.1 or 7.1 home theater receiver.
  • Source for TV programming (cable box, satellite receiver, or TV antenna).
  • Source for music (CD player, but a DVD player could also play CDs).
  • Set of surround sound speakers.
  • Subwoofer (optional, but highly recommended).
Wayne A. Pflughaupt
S205449
