Swanton
- May 22, 2008
- Michael
Hello everyone,
This is my first post although I have been contemplating working on a home theater room since moving into our house in 2006. I apologize if this is not in the proper section of the forum; just let me know and I’ll move elsewhere.
I am about a month or so away from committing to upgrade our “lounge” to a full-blown theater room. I would love to hear advice on the various types of hardware and installation I might pursue.
A few notes:
1.We are planning to get a 50-inch plasma HDTV and mount it to the wall where our current TV is placed. I realize this is directly across from three windows, and we are in the process of getting heavily lined drapes to “blackout” the light from the windows.
2.The two gold chairs are going to be moved to another room. The couch pictured will move up against the wall to the left of the new TV (facing toward the TV). We have another couch that will be moved upstairs that will go in front of the windows and directly face to TV. The couch is pictured below (it’s the brown one) and the chez can be flipped so it’ll be on the right side and not the left. The combination of the two couches should provide ample room for viewing.
3.We have had DirecTV for about 10 years, and have an HD TiVo receiver although we do not have an HDTV yet. I’m going to try to see if I can get an upgraded model from DirecTV before moving forward; the least they can say is “no.”
4.We plan to get a Blu-ray player, and I am leaning toward simply buying a PS3 because I enjoy videogames (see #5).
5.We have an XBOX 360 and I’m looking forward to playing games on a more epic scale in the room once the video and sound system are installed.
I have several questions, but I’d be happy to hear your thoughts on anything I have mentioned thus far. For example, I feel like I’m set on getting a plasma, but I know LCD is another option we could go with.
First, after doing some research and watching various TVs in action, I am leaning toward the Pioneer PDP-5010FD, but know there is an Elite model that adds another $1,000 or so. What do you think about the Pioneer? And is the Elite worth the extra cost compared to other TVs out there? Are there other 50-to-58 inch TVs you would recommend over this?
Second, what type of sound system would you recommend? We are considering whether or not to do everything wall-mounted or to have tower speakers in the front and speaker stands in the back. I heard that the wall mounted speakers (especially the surround) do not perform as well as free-standing speakers. Also, are five speakers plus a sub-woofer more than adequate?
Third, I will not be installing all of this myself. I am trying to determine the best place to buy the equipment and the best place to install the equipment. I know I could get everything at Best Buy and have them install it, but I’m not sure I trust them, and it would be more expensive then buying things online and then having a contractor come out to put everything together in the house. What would you suggest?
Last, I do not have a firm budget yet, but certainly could not go in for more than the 8K range. I think that should be enough to put together a kickass room for watching sports, shows and movies and playing games. How would you allocate that amount considering I need to buy the following:
HDTV
Speakers
Receiver
Sub-woofer
Blu-ray player (likely PS3)
Cables, etc.
Storage/cabinet
Installation
Also, is there anything else in terms of a “cherry on the top” that would be good for the room? I’m not sure what that might be, but you might have some ideas from seeing the room and hearing my thoughts.
If you read this far, then thank you very much! This turned into a longer message than I thought it would be when I first started writing.
Thank you.
A few notes:
HDTV
Speakers
Receiver
Sub-woofer
Cables, etc.
Storage/cabinet
Installation
Thank you.
